Thread: Startup Problem
  #12   Ban this user!
Old 03-02-2007, 05:19 AM
ASIGuy's Avatar
ASIGuy ASIGuy is offline
ASIGuy is on a distinguished road
Dont forget that there is a solid state (SS) relay on the Tri-Mag power supply that must energize before anything will come up, and that includes the power that runs the small icecube relays in the back panel. You can pull the SS relay on the Tri-Mag supply, short the output of the relay (be careful that you are shorting the correct holes in the board where the relay plugs in) and press or short the leads on the green "on" button to see if if starts. You should at least have the +5 and such from the Tri-Mag at this point if the Tri-Mag is good. If so, the problem is indeed with your ice cube relays in the rear panel most likely.
