Originally Posted by karamitrov1 It depends on the tolerance you need. You can easaly mounth a manual forth axis(low cost around 350 eur) used on the manual mills for making gear, sprocets than all you got to do is to make couple CNC programs for a smaller angle where undercating is not ocuring and manualy rotate the axis between the programs. I usuly engrave cilinders for marking and stamping that way. |
So simple, why didn't I think of that...
Great idea Karamitrov, sometimes the solution is too close to be seen.
