  #11   Ban this user!
Old 02-28-2007, 07:14 AM
ASIGuy's Avatar
ASIGuy ASIGuy is offline
ASIGuy is on a distinguished road
As Neil suggested, at the Enter Next Command prompt, I would type in DI then press enter, then DS and check the status of the switches. Make sure your machine is trying to shift from high to low gear when powered up, then after the CS procedure, do the DI/DS thing and check the switch status. Pay particular attention to the orientation sensor on the spindle pulley. It must be reading before the spindle spin much. The spindle will bump, read the switch and go from there. No switch input, and it will shut down and alarm for motor overload. If you want to try a drive, and all you pay is the freight, no restock, call FadalCNC.com and they will help you out. No tuning the AMP-0056 if this is what you have. Good luck.
