Hi Bullnerd,
How are you sending the program to the machine? Is it via a RS232 link up or via a network connection?
If it is via a RS232 connection I use the following header information in my programs and the machine takes the filename from this information.
$PPC-700009381OP1.MIN%
O9381
program here
M2
On our OSP-E100M machine, which uses a network connection, I do not need to use the 2 first lines stating the file name and program number, the machine picks up the name of the program from the filename on the server/pc it is connected to.
Hope this helps a bit.
Regards
Brian. |
