There are several ways to c-bore.
Try this.
1) draw circle at part top.
2) select circle and go to menu 'Other>Pocket>Spiral
3) Now set all the parameters includiong 'mark start' and if you intend to finish afterwards then click OK.
4) On NC side select the 'Tool Depth Settings' (up/down). Set the settings there including turning on the roughing if needed. This is where the depth is also set.
5) Selct path generated on the cad side if not alread selected. The entire path can be selected if you view in isometric and hold the shift key while clicking near the start line top.
6) On the NC side select the 'cut all'.
There are other ways to do this too. |
