  #10
Old 02-26-2007, 09:16 AM
tobyaxis's Avatar
tobyaxis tobyaxis is offline
Moderator
tobyaxis is on a distinguished road
Originally Posted by tjones View Post
Hmmmm.. I would normally select only the Top wire frame. Is there a reason you would select the bottom Toby? Or is this just a difference in preferences only? I select the top and go down for any code I do.
But Toby is correct in that you only select the one edge. If you select more than one then Bobcad is looking to pocket a second time.
More a matter of preference than anything else. I usually Machine with the 3D on. Set the Tool Up/Down, and DOC for Roughing.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
