I would recommend you send your files including post to your local dealer as they should be able to help you the best.
If you know how to modify a post processor then I would use the Generic Fanuc 4 axis and modify it's output to match your hurco machine. It is easier to change general formatting of the code output than it is to add rotary logic to a post.
Hope this helps
AC |
