Old 02-23-2007, 03:11 PM
danswaay danswaay is offline
danswaay is on a distinguished road
Hi Sotos,
The spindle upgrade for the Syil Super X3 is two things:
1) A new 1:1 ratio pully cog for the motor spindle connection
2) A daughter control board that will allow the PC to turn the motor on and off as well as control the spindle rotation speed etc.
There is a toggle switch on the front of the mill face that will put the spindle control in a "manual mode" or a "G-Code control mode".
Make sure that your "spindle control daughter board" is connected properly.
When I first got my CNC S-X3 mill from SyilAmerica, my spindle control daughter board was not connected at all and I did not know how to even use the toggle switch until I talked with Richard at SyilAmerica.com.
You might want to check your connections etc. Best of luck.
Regards,
Dan
