Another one spindle controll problem | | Hi
I am a new owner of Super x3 and I started to use this machine since last week. I am a totally beginner in the operation of such a machine and any other CNC machine and so I started slowly to use the controls by the keyboard to move the axis and then I started to load G codes. Everything was fine with what I did and I was very excited to see the movement of axis. The only wrong was that I couldn’t do anything with the spindle. The spindle could work well manually with the desired speed but NEVER by controlling from a PC. When I was switching on the PC the spindle was running to 2800rpm in PC controlled position and it was stopping after the loading of controlling software. When I was loading the G code there was an indication on the software of 1000 in the spindle speed field and 0 on the RPM field. I could here the relay when I was switching it on or off and when it was probably ON I could here a continuous noise from the board inside but I didn’t see the spindle to turn since I bought this machine in PC control position. Now I don’t know what is going wrong but when I turn on this machine the spindle is running to the max speed in both manual and PC control position while the indication in the speed indicator is 0 and I can’t do anything to stop it.
Any one knows what is finally the problem with this case? |
