Thread: Mid tape DNC
Old 03-19-2004, 09:07 AM
Neal's Avatar
Neal Neal is offline
Neal is on a distinguished road
Nervis--
Do not use the 32MP mode as this looks for an RS-422 port and locks out the baud rate selections. Make sure that you have the latest service packs from Microsoft for your Windows System and Internet Explorer 6.0 or later. There were some bug from Microsoft that were corrected with this fix.
Make sure that the VMC baud rate and the NC Fadal baud rate are the same. 'member that if you change the baud rate in the VMC SETP pages you MUST power off and then power back on for it to be effective. Temporarily you could use the CD command to over ride that SETP paramteter.
Make sure that you cable is wired correctly and a null modem is used if the cable is NOT wired null. Check your pin assignments closely. Diagrams are in the User's Manual in the communications section.
NEal
