He is talking about splicing the pieces together and join them with a skin pice glued to the pieces, then use a trim router but which had a bearing on the end usually a 1/4" bit. The bearing will follow the pattern piece and cut the new material to match.
I would do it with the patern on top and the stock material on bottom and use a router table so the bearing is ontop and you will always have a vertical cut. |
