I wonder if the bottom of the rotary table is flat enough.
It would be interesting to dye or marker the bottom of the rotary table clamp it down, and give it a little tap to rub the dye, and remove the rotary table to see how much contact area there is.
I also wonder if the bolts are close enough to the vice. |
