AINano:
If this is activated with a high degree of accuracy, then your feed rate should be increased. This is the point of this feature... If activated and no increase to feed is made, then your cycle time will be longer and of course geometry will be more accurate. Personally, this idea of using a variable to set machine accuracy performance is still a bit frustrating. This is the way it is with Fanuc and some other controls, even Fadal with it's Advanced Feed Forward option (point to point motion only), or even the G8 G9 setting.
I mean why can't a CNC machine just be accurate in it's behavior, not some compromise of accuracy, or speed. As a programmer/machinist do you program a feature with anything besides accuracy in mind? I don't.
If I want to go fast, I want to go fast accurately, period!
What about you?
BTW check out:
http://www.creat.com/
