Nervis--
Quickest and dirtyest (sp) method of doing a mid-tape start is to go to ENTER NEXT COMMAND and type AU,150 where the 150 represents the block number that you want to start at. This will cause the control to rapidly read thru the program and set all the modal codes needed at the starting block. When the search is done the control will go into the WAiTING state now just hit AUTO and your running.
The only caution is do not start in the middle of a drill or tap cycle or the middle of a subroutine or sub program.
Neal |
