Originally Posted by Rockomo Hello All,
I am using a Taig mill, cutting mild cold roll and trying to get a nice flat surface on a piece 1 in by 1.5 in steel. I was taking .001 cuts with a 7/16 HSS end mill on the 4th pully down. It seems like the cutter must me jumping as the surface in not totatlly flat as compared to a Enco mill result at work.
Any ideas.... Spindle adjustments?
..Rock.. |
7/16" is a rather large endmill for the Taig (although in this case you are using it more like a flycutter), and .001" depth of cut is incredibly shallow, which can cause it to skip a bit. Add to that that Cold Rolled can be hard to machine, is full of stresses, etc. and you get a difficult situation.
I would probably use the lowest speed on the pulley, more like a .01" depth of cut, copious cutting oil/coolant on the part with a slow feedrate.
