Not much point mounting a chuck. The rigidity issue is the MT2 arbor, so you may as well mount the workpiece directly on a MT2 arbor and take light cuts. You could mill the pulley conventionally, within say 20 thou over size, then finish it mounted in the spindle.
Just some thoughts
Regards
Phil
Originally Posted by digits Thanks, that's the one
He's only turning some pretty small diameter stuff - I have seen a couple of mini-lathe chucks with MT2 arbors that might fit my X-1, but they seem to be designed for tangs, not drawbars, and I really wouldn't want 1/2kg of metal spinning at 1000+ rpm falling out of my spindle! I suppose I could try drilling and tapping the tang though... |
