What am I missing here? I see:
1.5 HP spindle motor
Shorter travel distances, particularly Z
NO COOLANT
3000 RPM max (vs 4000 RPM on the Tormach)
Thousands more for program features that come with the Tormach
Rotary tables not advertised as 4th axis (don't know if they are or not)
BT30 Spindle, the Tormach is R8, I preferred the R8 myself with the TTS
The control is still a PC. You can buy a PC from Tormach, too, they will configure it for you.
Doesn't say whether faster rapids are from use of servos or whether they are compromising accuracy with gear ratio or running steppers at the high end. I would ask. You can push the Tormach a lot faster too, but then you run the risk of missed steps.
--97T-- |
