Old 02-12-2007, 06:39 PM
HayTay's Avatar
HayTay HayTay is offline
HayTay is on a distinguished road
Originally Posted by pntbllrsprky View Post
ok I have another question on dtl11. It says flanged bearings and mcmaster. I am putting together a parts list so I can order the parts. What exactly am I looking for. I looked quickly threw the drawings but I am lost. The parts list doesn't give me any dimensions
McMaster-Carr Flanged Bearing - Double Sealed 1/4 x 11/16" - Part No. 6384K352 - $5.19 US each
Also from McMaster-Carr: White Delrin Sample Sheet— Size is 6" x 6" x 1/2" - Part No. 8573K1 - $10.13 US each.
I know you're going to ask about this eventually, so I'll give you a 'heads up'. For all of the screws, nuts, bolts, washers and misc. hardware look to Bolt Depot. Good prices, fast shipping, parts in stock and no minimums! Make sure you order at least a couple of extra of each because you'll wind up using them for other things once you get the base table built.
You'll be looking for bearings, too. Either do a search on eBay or go to VXB Ball Bearings. Make sure that you get bearings that are sealed and/or double shielded to keep the dust and chips out of them. Again, order more than you need, without going overboard, as you will probably find other uses for them (like your next CNC Table) .
Happy shopping ,
HayTay
Don't be the one that stands in the way of your success!
