As far as I know (i could be wrong) but the only way to change the witness stile is to eather pre set it before making the dimension or use "change witness stile" to change the arrows.
As for the L key problem....I could have sworn i seen that same complaint soemwhere else....but then again i'm running on 2h sleep so i could be wrong. I'd check to see the button is assigned to the appropriate command.....(i'ts all i got) |
