Old 02-11-2007, 03:11 PM
pixburghenat pixburghenat is offline
pixburghenat is on a distinguished road
The other post said:
>I have also seen GENERAL PROTECTION faults with flaky power suppies, >overheating processor, or memory getting flaky.
Check and/or clean your power supply (blow out with some air)
be sure fan is turning.
From you pictures the machine looks very clean inside.
Reseating the memory chips can't hurt.
When you changed the battery, did you reset the CMOS and re-enter the correct data? If not, there may be some funky code in there.
floppy drive error won't give this type of info.
If you have a speaker on the MB, does it beep on startup?
enat
