The current post haste will not help you for this machine type. They are (gibbs and Ground support, the makers of Post Haste) adding support for Mill/Turn machines. This is an upgrade that you can buy and do the post work yourself. Post Haste would be MUCH more user freindly than Gibbs's Compost.
As for the predator editor, DON'T GO THERE. There are TOO many things to edit there, 2 files, sync codes, wait statments and many more.
Check with your reseller and find out when the mill/turn support for Poste haste will be avalible.
Also, Keep on Gibbs for the changes/fixes on your MTM post. You paied for it right? Don't let them get away without making it right for you.
Try to contact Gibbs Directly, ask to speak to the Sales Manager for your area.
GOOD LUCK
GG |
