Old 02-10-2007, 09:28 AM
ger21's Avatar
ger21 ger21 is online now
You should be able to do it with pretty much any router or mill. What you're asking for are basic operations.
The only issues you would run into would be spindle rpm (too high can result in melting) and, as was mentioned, whether or not you need to use a coolant. Coolant wouldn't mix well with a wood framed machine.
