Thread: Surfaces
  #12   Ban this user!
Old 02-10-2007, 07:53 AM
lagrandebug lagrandebug is offline
lagrandebug is on a distinguished road
Create that surface as one
I use surfcam for some nasty parts the best way to get those surfaces together is not to join them it moves and alters them way to much. The best way is to create a spline thru the wire frame boundaries and then go to create, surfaces, DRIVE SURFACE that will let you pic what contour along what shape you would like your suface and where you want them to attach that will then create one big surface that you will be able to then do a 3axis cut on. Let me know if you need any help with it would be happy to show you. ALSO if you go to join surfaces and get burned there is a way to UNDO that. People learn the software before you go saying it can't do something that is how it gets a bad name. Let me know if you want to know where the UNDO BUTTON is.
