Surfcam does have some what of a undo button. If you do something and you don't like the results then most of the time you can go delete that like or surface and then hit "UNDELETE LAST" hit is once and the one you don't want will come back hit it again sometimes two or three times then go in and erase the result you didn't want and most the time the original will be there under it. Let me know if it worked for you |
