Old 03-12-2004, 03:31 PM
mtlmnchr mtlmnchr is offline
mtlmnchr is on a distinguished road
aight here ya go...
hit feed hold button. machine stops
type x,y,z,or a on the keyboard, not the axis select
hit [handle jog] key machine will beep, and flash jogging [?] axis ? = axis you selected
if you punch an invalid axis it will tell you that and you can push [cancel] to remove the notice then restart with the correct axis name typing ...remember ...it is the typing key not the axis select key.
If you chose to move more than one axis during this method it will allow it ...but remember while the machine is supposed to replicate your moves in reverse, machines do as they please sometimes ...if you need to move multiple axis I would suggest being very very careful on the re-entry to part.
you can also stop the spindle at this point to change the inserts.
when done just hit cyle start, the spindle should start, then the moves will begin
