Hi I did type it wrong and I changed it to L1 & L3 for these Hitachi drives should be connected for 240 V single PH and AL you can use any wire you want as long as it is correctly colored or marked so it is clear what that wire is, this does not Violate any codes.Also as J Raef has said you do not have
to jumper L1 & L2 for it will have no gain
Yaskawa VFD Drives are L1 & L2 for single PH
__________________ Mactec54 |
