Old 02-07-2007, 08:11 PM
moldcore moldcore is offline
moldcore is on a distinguished road
Nigel,
If you have a legit copy, you should still be able to get on the Webforum. All you need is an account number from when you purchased KeyCreator. It’s in the “Help/about” info.
As for the L and the X keys, you should be able to find out if they are assigned to the right functions under Tools/Customize/ Commands tab. You may have more than one command assigned to L key if that’s even possible. You can assign whatever command you want to any key there. Make sure you have the “Save current Workspace on Exit” checked in the Tools/Option/Startup window to save any changes to the hot keys. Good luck.
