The problem with the 240MSB model is they are belt driven, where the 2500SY is direct drive...
The Acceleration/Deceleration is much quicker with Direct Drive... it could save 30seconds or more, depending on you spindle direct and rpm changes
You will you the -Y- more than you think...
If you plan on making parts with "On Center" (X-Axis work) Keyways there is no way to adjust them... unless you have a -Y- axis...
__________________ ~Tony~
{Process Engineer, Lead Machinist, Supervisor, Computer Enthusiast, Linux & M$ User} |
