Old 02-03-2007, 04:09 PM
N4NV N4NV is offline
N4NV is on a distinguished road
I was able to get the motor to run by manually pressing in the contactor. It sounds good, though there is noticable vibration at the max speed of 3,800 rpm. I cleaned up the knee ways and moved the knee up and down. There is noticable staining on the ways that could be rust. I can't feel it with my fingers but it is a rust color.
The one shot lube system is working. There is a 120V solonoid on the top of it and I thought it might be controlled by the AB system. There is a manual plunger that I operated 10 to 15 times over the course of an hour and I finally did see some oil dripping out of the quill. That's good since I could not find any lubrication point for the quill.
If I can't get into the contoll system I have been looking at some Pixies contollers that will work with Mach3.
One other nice thing I have found is though the machine takes 3 phase, the only three phase item on it is the quill motor. I could run everything else from single phase and separate out the motor wiring and run it through a VFD. Right now I have the mill at my work and we have three phase here, but I have only single phase at home.
Vince
