Old 02-01-2007, 11:20 PM
EPAUTOWELDING EPAUTOWELDING is offline
EPAUTOWELDING is on a distinguished road
If you make the ram come to a dead stop something is going to give(break). I would sugest an adjustable relief valve. Set the relief where you have enough pressure to bend the wire against a stop (physical like trubleshtr said) and then relieve sending the fluid back to the reservoir. You would need one on each ram but this would stop them at the right place every time and not break a thing. good luck EP
