I am new to this whole thing so please bear with me. I have finished setting up my sieg x3 with the cncfusion kit and all the other necessary hardware with the exception of limit and home switches. I am now trying to use the mill to machine the mounts for the switches. To home the machine temporarily i wired up some switches and press them when the machine reaches its home travel. It works okay because i will then press the soft limit switch in Mach and the mill wont go past the soft home. The problem I am running into is this. I designed the part in Mastercam X, Its very basic and very small, roughly 2*2 inches. I am using the default mill/generic mill for my machine type. When I import the nc file into Mach i get a giant red box with red lines leading to the part. The part will not go onto my machine table in the toolpath view in Mach regardless of how I position the table and click regen toolpath. When I try to run the program the machine will soft home itself and then it will ask for the tool change, i click continue cycle (since i wanted to demo it first on the machine i just have a pen mounted), and next it immediately says "softlimits switch thrown" or something to that effect. I am including the file so if i am doing something wrong in that yall can look at it and tell me. |
