Question about calculations for worm gear hobbing...
I'd like to try hobbing a few worm gears and would like to know how to calculate OD etc. I've found the GearSpec program from W.M. Berg
http://www.wmberg.com/ but the deal is, I'd like to use a 1/10 pitch .500" Acme screw for the worm. I know this isn't a true worm, so the question is - is the data provided by this program close enough to create a servicable worm gear using the Acme threaded rod?
PDF attached with worm gear data
