The Tri-Tech 5 axis head is probably the only real plug and play kit for the Fadals. It does have it's quirks, like the servos attached to the head, and some minor accuracy issues depending on who you talk to. Not as rigid as an OEM 5 axis machine. You will lose work envelope that maybe acceptable on a 6535/6030/8030 but substantial on a 4525/4020. And not cheap.
But cheaper than buying an OEM 5 axis machine and you will have true, full 5 axis capability. They also have full 360 degree rotary movement and the spindle will tilt 180 degrees. I do know shops that use it and they are happy with it.
Personally, I wish I had bought one when I still had my shop. I had to turn away a lot of work because I lacked full 5 axis and/or 3+2 machining capability that required single setups. |
