IPM, I believe, is the most basic parameter for controlling the rate of motion. If you are given IPT, then the control must also know how many flutes are active and what the rpm is, in order to then calculate the feedrate for the servo. The velocity for the motor has to be distance/time.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
