No feed rate control on lines | | Hi Adobe,
Well we have everything working good except there is no feedrate control on G01 line moves , it doesn't matter what we put the feedrate at in G code, it travels at the same rate. We do have feedrate control of circles since we unchecked the box in Machine Config. to Break Arcs into line. You will notice that we only have 2 axis checked for now, we will worry about Z latter. I have attached all our set up sheets for you and a pic of the machine.
What do you think the problem may be?
Thanks |
