  #11   Ban this user!
Old 01-17-2007, 04:40 PM
manhasset manhasset is offline
manhasset is on a distinguished road
not a perfect circle
Originally Posted by ScoobyDoo View Post
WE use FeatureCam for our CNC programming. Can someone tell me why every now and then the cutter path will stop and cut a perfect circle into the job (usally scrapping the piece)?? This only ever happens during the roughcut. WE have HAAS's, Bridgeports and JohnFords and this has happened on all of them at one time or another. The problem is that this circle cut does not show up when you view the cutterpath in FeatureCam but is obviously being posted out with it!!! The last time all we did was load the surfaces back in as iges instead of step and the circle cut went away???????
Any help would be greatly appreciated!!!
make sure you do not have on part line program found in the properties tap where you click cut comp. try it
