Old 01-17-2007, 06:29 AM
greybeard's Avatar
greybeard greybeard is offline
greybeard is on a distinguished road
DIY grit-covered feed rollers
I'm planning to use a powered feed roller for the x-axis drive, and would like to hear anyone's experience with the diy construction of a grit covered roller.
In its first build it will be moving 8"wide x 36" long x 1" thick material, which will be supported on an air bed each side, but when developed, it will be upgraded to move material 24" wide x 72" long.
1" diameter pressure rollers spaced 6"apart on top, parallel and either side of the cutting area, with a vac/brush dust removal between them.
The drive roller needs to be 2-3" in diameter, and 10" long to start with, later version 26" long.
There seem to be at least 4 approaches : -
1. start with an existing metal roller and coat it with an epoxy/sand layer - no seams, good, but needs lucky find.
2. Ditto roller, but with spiral wrapped sanding belt, secured at each end - must be bidirectional.
3. Make the roller from laminating a set of wooden discs, then cover it as in 1. or 2. - needs lathe to true up the surface.
4. Run steel shaft through pipe with wooden end blocks inside - trueing up ?
Further ideas/ comments/ experience welcome.
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
