Thanks for sharing your experiences.
I'm currently running a MaxNC 10CL. It took a lot of time to me to make the machine “workable”. Adjusting gibs, servo errors, etc. You know all that…
Maybe it’s too early but based on your MaxNC experience how does the Syil conversion comparable to the MAX? I know it’s a different league. But since you have a MAX I dare to ask.
Are you planning to cut stainless or aluminum? I prefer alu and my concern it that the Syil is a bit slow for alu. Ok you can cut deeper but how about surface finish?
How is accuracy comparable to the MAX? Max has a really good closed loop controller (if you fix the servo errors)
What is your impression about the syil’s controller?
Thanks,
James
Vancouver,BC |
