Old 01-16-2007, 12:36 AM
Chris64 Chris64 is offline
Chris64 is on a distinguished road
Originally Posted by BobWarfield View Post
3. Clamp the plates horizontally on a fixture plate that has cavities contoured to hold the side bulges. Set up an index pin so you get it index properly and clamp by bolting through the side holes to your fixture plate. Now you can mill out the edges and the individual parts are held by the side holes, so you can get a clean pass on them. In order to keep the production line running smoothly, you may want to arrange to clamp your fixture plate for this operation in the two Kurt vises.
Thanks for the suggestions. That's one of the idea's I was considering. The side holes are REAL small so using them for mounting isn't really an option (#60 drill I think...around .04" diameter). But that top piece may be enough to clamp on to (around 1/8 of flat space before the bearing bevel).
I was thinking of cutting a block of alum to hold 4 of these side by side. Each for one of the position changes. Then I could run a program that cuts all 4 in one process...then I would move everything one step down on the assembly and start the run over again.
I also read idea's about leaving a couple tabs a few thousands of an inch thick and then just cutting it off with an exacto blade. It's manual labor, but the clean up should be minimal.
