Derek,
Your setup is a piece of garbage. Get it.
Due to the setup of my block I need to run my water outside and collect it in a sump and utilising a sump pump, pump it direct to the garden or a holding tank with another pump to use as I see fit.
Sump pump with a tank is preferred, at this moment getting the water outside is the hard bit.
Cheers M
