  #11
Old 01-13-2007, 10:48 AM
LJ48 LJ48 is offline
*Registered User*
LJ48 is on a distinguished road
Smile First prog.
I have found on hexes Coversational Prog. works better for me.
What I did was make a program for a 1 inch hex ( 1 inch across flats) then I added a "scale" then I
put in the correct num to make new hex . If the new hex is 1.5 across flats put in 1.5 if it is 5/8 across flats you would put in 5/8.
Be sure to run the graphics before you run first part. The graphics ,i think is one of the most important things to learn on this machine. It has saved me from many baaad things.
I think "scale" is under the "special" key.
