Old 01-13-2007, 10:22 AM
LJ48 LJ48 is offline
*Registered User*
LJ48 is on a distinguished road
Fast jog
The info you need is in the parms. section.
1 Get to main screen.
2 F7 (Params)
3 F1 (set-up )
4 F1 ( level )
A "validation code:" type in "proto3" (with out quotes ) hit enter
B "access level" type in 3 enter
5 F4 (axis )
A curser down until you find "slow jog velocity" or "fast jog velocity "
B select the one you want
C F1 (edit) now you should be able to change X,Y or Z axis to the rapid you want.
After you are done just hit "esc" 2 or 3 times to get back to main screen.
Sorry I don't remember what max. rapids were for this mach., may want to ck. manual or call Miltronics.
You may have to restart machine to get changes to
get changes to take place. These 2 rapid params should be pretty safe to change as long as you dont go over max.
hope this helps
