Big emergency...Really need help | | Hello everybody,
You could be really REALLY very kind to help me because I MUST make a work this WE and if I don't do it, I will be fire!
I have a TAIG system 2000. It uses MACH3.
The problem = I never succeded in started up the machine.
If you don't mind, let me explain to you my setups and please tell me what could be wrong :
Supply box : The XYZ axis cable of the machine are properly connected to my PC. My PC port has the 378 address and I have choosen port N1 : 0x378.
my parralel cable is OK.
In mach3 :
Imput / outputs
X axis : enable, step pin3, dir pin2, (Dir low active + step low (both non active)).Step port = 1, Dir port = 1 Y axis : same but step pin 5, dir pin 4. z axis : same but step pin 7, dir pin 6.
Jog button is on.
Imput signals : jog X++ and y-- enable port1 pin 11, (active low + emulated + hotkey) = not active. Y++ and Y-- > port 1 pin 12 ( oher settings = identical). z++ and z-- > port 1 pin 13 (other settings = identical).
On Diagnostiscs Alt-7 screen >
port1 pin current state : 4, 5, 6, 7 and 8 are in yellow.
Alt-Ejog X+ and - / Ejog y+ and -/ Ejog z + and - are in yellow.
output signals current state > enable 1 is red
Once again, if you help me, you are to me the most important person to me for years!
Many thanks in advance for your help and comments.
Warm regrds.
Manley |
