If you down load the Assembler/Linker manual it gives examples as to what is happening and how to get rid of it.
I ran into that the first time I used it, your program probabally can be compiled without the Lkr file, but in this instance you need to edit the Linker file, get rid of the NAME=vectors line and change the NAME=page start to 0x0000
If you are not using the interupt vector section.
Like I mentioned, they give a detailed example in the MPlab manual.
also remove the SECTION NAME=STARTUP ROM=vectors line for now.
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
