  #11   Ban this user!
Old 01-10-2007, 04:44 PM
Aksess's Avatar
Aksess Aksess is offline
Aksess is on a distinguished road
First off the laser tube was broke when I received my machine.
1)you will weld the laser tube and fix the problem under our instruction by MSN camera
no I installed it myself and all was fine. It was a simple install almost anyone could have done.
2) you will send the machine back if you meet any other problem because you have done too lot about our machine without our permission when it is still in warranty
I never agreed to send the thing back at anytime. If you rember I said there was no way I could aford to send it back to China.
I have done a lot to OUR machine? I do rember paying the company in full for it.
As for doing a lot to it. I replaced the bad laser tube that I had no idea was bad when I received the machine, The bad tube caused the laser tube power supply to burn out. The first day I had it.
So I guess it is my fault that the machine was not working when I received it.
I honistly think I was on the receving end of a poorly built machine.
Anyway I have someone intristed in buying it, He seems a bit more knowladgable of electronick so he may can still make a good machine of it.
