Turner,
I'm not sure how to get there off the top of my head, but Keep Relay 3 bit 0 (farthest right bit) controls whether the spindle and coolant stop when Feed Hold is pressed. Your control is probably set to 0 (and I quote): "Feed hold operates but spindle and coolant don't stop."
Set this keep relay to 1 (again I quote): "Feed hold operates and spindle & coolant stop. However, in case of executing fixing cycle for thread cutting or tapping, operation will be stopped after finishing actual machining part."
You need to be in MDI, go to Settings, and turn PWE "ON", then go to the System display... that's where I run out of recollection.
Dave |
