Here is one I saw while visiting ShopBot in Raleigh, NC. Pretty simple and hooked up to a vacuum cleaner. The plate at the front is what regulate the amount of vacuum. The grooves where sealed with clear varnish bottom and side. The parts are caulked together to avoid vacuum leaks.
__________________ Paul Riedlinger
Let the chips fall where they may...I'm not going to clean them up!
