Thread: Taig CNC help
Old 02-26-2004, 10:56 AM
Grimracer's Avatar
Grimracer Grimracer is offline
Grimracer is on a distinguished road
Re: hmmm
Originally posted by WOODKNACK
try running the program dry. What i mean is all setup so the cutter doesnt actually come down and touch the wood. then run the program. see if the same thing happens. if so then its not the wood! what size stepper do you have on it. how fast can you move around the axis before the stepper start to skip?
Also could be the software you are using! I switched to turbo cnc and have not had any problems. great hobby software.
Woodknack
First thank you for hepling me out. Here is what i have seen and the info on the machine...I made a rime...
Anyway,
I bought the uint from Microproto and its box stock. Meening the steppers and the driver and the programs offerd with the unit.
Lets see...
MPSPRO (this is the DOS program,,is this the Gcode program)
Millwizard (cam program)
MACHINE SPECIFICATIONS:
Maximum Travel Speed: 30 in/min. (no idea who makes them)
Maximum Travel: X = 12", Y = 5.5", Z = 6.0"
The machine as only done this while not cutting but rather passing over the part to say,,,start a new cut.
Its under no load when this happens.
Thanks again.
Mike "grimracer" Z
RC stuff..coool me to...
www.grimracer.com
you have the right to ROCK
