Thread: Taig CNC help
Old 02-26-2004, 08:23 AM
Grimracer's Avatar
Grimracer Grimracer is offline
Grimracer is on a distinguished road
Taig CNC help
I received my CNC machine and have it up and running at my home location (Power Surge Racing Products, LLC.)
I have a question.
While running the unit it will sometimes stutter (buzz as if to misunderstand or hang up) and i will loose my 0 position (so far X and y only). I have to press the space bar to get it to stop and then it will start right up again using the (C) key.
I switched steppers with the Z unit and same thing (X travel). the bed is free and very smooth.
Is there a chance that i have the feed rate to high? I'm just testing on bass wood and making .050" cut depths. Is 10 to 24" a minuet to much feed? The unit says it can do 30IPM
seems to me that the feed can be changed in the cam program or the MPS running screen? Witch should i use
Hope you can help and that you understand my question.
Best Regards
Mike
you have the right to ROCK
