Old 01-06-2007, 10:36 AM
Jim Estes Jim Estes is offline
Jim Estes is on a distinguished road
I bought V21 the other day.
I ordered V21 the other day because I needed another seat. From what I have read about V21, there isn't a lot of changes from V20, that I have been using. Other than the help file issue, is there any other things I need to look out for. I know that when I switched from using V17 to using V20, there was an issue, I forget what it was, but there was an issue that caused me to scrap some parts, I believe is had to do with pocketing, and the "finish" cutting function, it didn't do what I had thought it would do.
Does the V21 book have more in depth info in it, or it pretty much the same as V20 with a new cover?
I personally won't have a problem with not having the help filFor es, I never use them anyway. As for the videos, they weren't much help either, since they don't show how to fix your mistakes just how to do the right things.
I would love to see more in-depth explanation of how the software uses the numbers in the dialog boxes, to generate the G-code. And how the order in which you pick your geometry affects the way that your solid surfaces are created.
I guess all of this could be part of a "wish list" for future BCC books, and videos. As for the software itself, I would love to see more functions for manipulating and modifying surfaces. Although, the combination of functions that are available will do almost anything I want them to do, I sometimes find myself fudging, things or giving false numbers to get the results I need.
For example, when I need to generate a toolpath on a surface, but I need the cutter to go down below the lowest point of the surface, I have to create geometry below the lowest point in order to get BCC to cut it that deep. Simply putting in a Z value in the Z Extents box, below the surface doesn't get BCC to cut it that deep. The function only works to keep the cutter from going too deep, it won't allow me to send the cutting deeper that the surface, which forced me to create a surface that is as deep as I need to cut the part.
It's things like this that I have had to learn as I go. I wish a lot of this type of stuff was in the book, or more options in the next version of the software.
Jim
www.maverickmoldandtool.com
